Revision 2
A project log for paperd.ink
Low power e-paper dashboard using ESP32
rohit-gujarathiRohit Gujarathi 05/09/2021 at 11:480 Comments
The revision 2 PCBs are here! This revision contains quite a few changes to simplify manufacturing as well as lower the sleep current. These have a green solder mask but eventually will go for the original white one.
The front panel is removed since it was difficult to manufacture reliably and was adding a lot of cost. 4 tactile buttons have been added instead.
The dependency on PCF8574 for controlling a few of the IOs is removed and is now only connected to the expansion header. So it's easy to control the e-paper without the overhead of I2C communication with PCF8574.
The CP2104 circuit is changed to bus powered, so it consumes power only when connected to a host. The LDO is changed to XC6220B331MR-G which has a lower quiescent current. These changes helped reduce the sleep current quite a bit.
The sleep current is well below 20uA now!
