Difficult to read clock
I made a clock that is intentionally difficult to read.
Clock cycles through showing the hour, minute, and second at a position and brightness determined by a floating sensor pin updated every 50msVideo of clock in action:https://youtu.be/qGgOE4frbZk
agfa wrote 01/16/2020 at 12:12 point
Maybe you should check connections. Hope that this problem would not apper in my car and I would drive safely like https://studyhippo.com/drive-safely-31064/  article said. It looks annoying and bad.
P.S: why was my comment deleted?
[deleted]
solmanac wrote 01/15/2020 at 21:37 point
The connections are fine. I coded it to flicker in accordance with semi-random sensor values. For some reason I like making difficult to read clocks.
