The link to Jiří Praus' Arduinoflake.
The link to LuckyResistor's SnowFlakeProject.
After connecting FeatherSnow with your computer using a USB cable, a drive named "CircuitPython" will show up. You can drag your circuitpython file to the drive or you can connect it with a serial terminal. Here is the screenshot.
