My Pew Pew M4 arrived this week. Naturally I am working on getting my previously developed games working on it. Blinka's Breakout is next up! Unfortunately my button handling code is not very portable beyond the pybadge/pygamer devices. I've reworked it a bit to use ugame and it's now working on the Pew Pew.
Some of the colors are off a little bit (blue fire, yellow ice, red water!) but everything seems to be functioning correctly
foamyguy
About the colors, are you re-initializing the display in your code? Because if you do, you need a different initialization string for the displays I'm using. For portability, it's best to just use board.DISPLAY, then you don't have to worry abut it.
Also, did you receive the case for it?
