Hello World - LCD Edition
A project log for Electronic Load 3.3V-16V 1A
Electronic load that supports 3.3V-16V at 1A of current. Equipped with keypad, LCD, rotary encoder, STM32 Microcontroller and more!
schwarzrmsuschwarzrmsu 12/19/2019 at 02:570 Comments
The LCD when powered looks so cool, lets make it say something now!
This has definitely been the hardest part yet, and will most likely be a work in progress as the SW matures.  Later versions are going to take a number of inputs and map them onto the display to show information related to the electronic load performance.  For now I simply want to create a function that will print a string onto the LCD.  I started by generating functions to initialize the LCD functionality:
void LCD_functionSet(void)
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_15, GPIO_PIN_RESET);    //RS
    HAL_GPIO_WritePin(GPIOC, GPIO_PIN_10, GPIO_PIN_RESET);    //RW
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_8, GPIO_PIN_RESET);    //DB7
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_7, GPIO_PIN_RESET);    //DB6
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_6, GPIO_PIN_SET);        //DB5
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, GPIO_PIN_SET);        //DB4
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_4, GPIO_PIN_SET);        //DB3
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3, GPIO_PIN_RESET);    //DB2
    HAL_GPIO_WritePin(GPIOD, GPIO_PIN_2, GPIO_PIN_RESET);    //DB1
    HAL_GPIO_WritePin(GPIOC, GPIO_PIN_12, GPIO_PIN_RESET);    //DB0
    HAL_GPIO_WritePin(GPIOC, GPIO_PIN_11, GPIO_PIN_SET);    //E
    delay_us(1);
    HAL_GPIO_WritePin(GPIOC, GPIO_PIN_11, GPIO_PIN_RESET);    //E
    delay_us(40);
    return;
void LCD_displayOnOffControl(void)
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_6, GPIO_PIN_RESET);    //DB5
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, GPIO_PIN_RESET);    //DB4
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_3, GPIO_PIN_SET);        //DB2
    delay_us(1);
    delay_us(40);
    return;
void LCD_clearDisplay(void)
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_4, GPIO_PIN_RESET);    //DB3
    HAL_GPIO_WritePin(GPIOC, GPIO_PIN_12, GPIO_PIN_SET);    //DB0
    delay_us(1);
    delay_ms(2);
    return;
void LCD_entryModeSet(void)
    HAL_GPIO_WritePin(GPIOD, GPIO_PIN_2, GPIO_PIN_SET);        //DB1
    delay_us(1);
    delay_us(40);
    return;
Now that I have initialized the LCD, I can send commands for the different characters and it will print the characters onto:
I started with a function to print the letter A:
void LCD_print_A(void)
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_15, GPIO_PIN_SET);    //RS
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_7, GPIO_PIN_SET);        //DB6
    delay_us(1);
    delay_us(40);
    return;
 I ran a simple combo of these functions in main to test the functionality:
LCD_print_A();
delay_ms(1000);
LCD_clearDisplay();
I made similar functions for the other letters of the alphabet, along with space and key punctuation.  The next part is deconstructing a string and printing each letter individually.  Below is the function I created to accomplish this:
void LCD_printString(char string[])
    char stringInitial[21] = "";
    char stringCopied[21] = "";
    char* stringPointer;
    uint16_t i = 0;
    strcpy(stringInitial, string);
    uint16_t stringLength = strlen(stringInitial);
    //UART_printlnString(&huart2, stringInitial);
    while(i < stringLength)
        stringPointer = &stringInitial[i];
        memcpy(stringCopied, stringPointer, 1);
        if(strcmp(stringCopied," ") == 0)
            LCD_print_SPACE();
        else if(strcmp(stringCopied,".") == 0)
            LCD_print_PERIOD();
        else if(strcmp(stringCopied,"/") == 0)
            LCD_print_FWDSLASH();
        else if(strcmp(stringCopied,"0") == 0)
            LCD_print_0();
        else if(strcmp(stringCopied,"1") == 0)
            LCD_print_1();
        else if(strcmp(stringCopied,"2") == 0)
            LCD_print_2();
        else if(strcmp(stringCopied,"3") == 0)
            LCD_print_3();
        else if(strcmp(stringCopied,"4") == 0)
            LCD_print_4();
        else if(strcmp(stringCopied,"5") == 0)
            LCD_print_5();
        else if(strcmp(stringCopied,"6") == 0)
            LCD_print_6();
        else if(strcmp(stringCopied,"7") == 0)
            LCD_print_7();
        else if(strcmp(stringCopied,"8") == 0)
            LCD_print_8();
        else if(strcmp(stringCopied,"9") == 0)
            LCD_print_9();
        else if(strcmp(stringCopied,"A") == 0)
            LCD_print_A();
        else if(strcmp(stringCopied,"B") == 0)
            LCD_print_B();
        else if(strcmp(stringCopied,"C") == 0)
            LCD_print_C();
        else if(strcmp(stringCopied,"D") == 0)
            LCD_print_D();
        else if(strcmp(stringCopied,"E") == 0)
            LCD_print_E();
        else if(strcmp(stringCopied,"F") == 0)
            LCD_print_F();
        else if(strcmp(stringCopied,"G") == 0)
            LCD_print_G();
        else if(strcmp(stringCopied,"H") == 0)
            LCD_print_H();
        else if(strcmp(stringCopied,"I") == 0)
            LCD_print_I();
        else if(strcmp(stringCopied,"J") == 0)
            LCD_print_J();
        else if(strcmp(stringCopied,"K") == 0)
            LCD_print_K();
        else if(strcmp(stringCopied,"L") == 0)
            LCD_print_L();
        else if(strcmp(stringCopied,"M") == 0)
            LCD_print_M();
        else if(strcmp(stringCopied,"N") == 0)
            LCD_print_N();
        else if(strcmp(stringCopied,"O") == 0)
            LCD_print_O();
        else if(strcmp(stringCopied,"P") == 0)
            LCD_print_P();
        else if(strcmp(stringCopied,"Q") == 0)
            LCD_print_Q();
        else if(strcmp(stringCopied,"R") == 0)
            LCD_print_R();
        else if(strcmp(stringCopied,"S") == 0)
            LCD_print_S();
        else if(strcmp(stringCopied,"T") == 0)
            LCD_print_T();
        else if(strcmp(stringCopied,"U") == 0)
            LCD_print_U();
        else if(strcmp(stringCopied,"V") == 0)
            LCD_print_V();
        else if(strcmp(stringCopied,"W") == 0)
            LCD_print_W();
        else if(strcmp(stringCopied,"X") == 0)
            LCD_print_X();
        else if(strcmp(stringCopied,"Y") == 0)
            LCD_print_Y();
        else if(strcmp(stringCopied,"Z") == 0)
            LCD_print_Z();
        //UART_printlnString(&huart2, stringCopied);
        i = i + 1;
    return;
This function takes a string, and looks at each character one by one.   If the character matches a known character in the "if statement", then it prints that character onto the display.  The while loop goes through each character until it has gone through the entire string length.
Running the following function with "HELLO WORLD" gets the following result:
LCD_printString("HELLO WORLD");
delay_ms(1000);
LCD_clearDisplay();
