Getting To Blinky
A project log for Electronic Load 3.3V-16V 1A
Electronic load that supports 3.3V-16V at 1A of current. Equipped with keypad, LCD, rotary encoder, STM32 Microcontroller and more!
schwarzrmsuschwarzrmsu 12/12/2019 at 01:230 Comments
Now that I have connected successfully to the microcontroller, the logical next step is to blink an LED.  I simply plan to test the functionality of the Debug RGB LED by writing some code to turn on and off each element of the RGB LED:
Microcontroller Pins:
Debug RGB LED:
I wrote functions for each LED for Turn On and Turn Off.  I included Red, Green, Blue and all other color combinations.  This will make it easier to toggle these LED's once the code gets more complicated:
void TurnOnRedLED(void)
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_9, GPIO_PIN_SET);
    return;
void TurnOffRedLED(void)
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_9, GPIO_PIN_RESET);
    return;
void TurnOnGreenLED(void)
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_10, GPIO_PIN_SET);
    return;
void TurnOffGreenLED(void)
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_10, GPIO_PIN_RESET);
    return;
void TurnOnBlueLED(void)
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_11, GPIO_PIN_SET);
    return;
void TurnOffBlueLED(void)
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_11, GPIO_PIN_RESET);
    return;
void TurnOnYellowLED(void)
    return;
void TurnOffYellowLED(void)
    return;
void TurnOnPurpleLED(void)
    return;
void TurnOffPurpleLED(void)
    return;
void TurnOnCyanLED(void)
    return;
void TurnOffCyanLED(void)
    return;
 I added some simple code in the main while loops to test each function:
  while (1)
      TurnOnRedLED();
      HAL_Delay(1000);
      TurnOffRedLED();
      HAL_Delay(1000);
      TurnOnGreenLED();
      HAL_Delay(1000);
      TurnOffGreenLED();
      HAL_Delay(1000);
      TurnOnBlueLED();
      HAL_Delay(1000);
      TurnOffBlueLED();
      HAL_Delay(1000);
      TurnOnYellowLED();
      HAL_Delay(1000);
      TurnOffYellowLED();
      HAL_Delay(1000);
      TurnOnPurpleLED();
      HAL_Delay(1000);
      TurnOffPurpleLED();
      HAL_Delay(1000);
      TurnOnCyanLED();
      HAL_Delay(1000);
      TurnOffCyanLED();
      HAL_Delay(1000);
I then compiled and loaded this code to the micro and tested the SW:
Red:
Green:
Blue:
Yellow:
Purple:
Cyan:
