pvb.xlsx
Design workbook for balancer & charger.
sheet - 326.89 kB - 06/10/2022 at 21:00
Download
pvbb-210518.zip
KiCad 5.x balancer project (final).
Zip Archive - 1.64 MB - 06/10/2022 at 20:31
Download
pvbcb-210218.zip
Kicad 5.x back-plane project (final).
Zip Archive - 226.76 kB - 06/10/2022 at 20:31
Download
pvbcs-210603.zip
Kicad 5.x SEPIC card project (final).
Zip Archive - 93.83 kB - 06/10/2022 at 20:31
Download
pvb-firmware-support.zip
Firmware support files for Balancer & Charger projects. Place in a folder used for includes across all projects and add path to project properties.
Zip Archive - 2.14 kB - 05/23/2022 at 17:42
Download
pvbb-210518-fw-v2_0.X.zip
Balancer firmware (final).
Zip Archive - 554.30 kB - 05/23/2022 at 17:39
Download
pvbc-210218-fw-v3_0.X.zip
Charger firmware (final).
Zip Archive - 631.11 kB - 05/23/2022 at 17:39
Download
pvb-common.X.zip
Project files common to Balancer & Charger firmware.
Zip Archive - 6.44 kB - 05/23/2022 at 17:39
Download
chgbal-48v-charger-sepic_continuous-250w-150khz-58u-transient-hs_ct.asc
Final LTspice model used to validate the prototype 200713.
plain - 7.25 kB - 09/01/2020 at 16:41
Download
sp-kicad-200713.zip
SEPIC prototype PCB project in Kicad.
Zip Archive - 401.56 kB - 08/29/2020 at 03:45
Download
sp-mplab-200713.x.zip
SEPIC prototype firmware.
Zip Archive - 486.77 kB - 08/29/2020 at 03:44
Download
chg-sepic-prototype-150khz-200713.xlsx
SEPIC prototype design workbook.
sheet - 94.38 kB - 08/29/2020 at 03:42
Download
chgbal-48v-charger-sepic_continuous-250w-150khz-ind-rm12-58u-r1.pdf
Titan analysis of coupled inductor design for 150kHz prototype evaluation.
Adobe Portable Document Format - 66.66 kB - 07/13/2020 at 23:07
Preview
Download
chgbal-48v-charger-sepic_continuous-250w-150khz-58u-transient.asc
Updated LTspice model with peak current limiting, C_ac/L_l resonance, and snubber.
plain - 7.21 kB - 07/13/2020 at 22:54
Download
chg-sepic-prototype-150khz-cc_snub.xlsx
Completed design workbook for prototype build evaluation.
sheet - 75.25 kB - 07/13/2020 at 22:53
Download
chg-sepic-prototype.xlsx
Prototype design workbook.
sheet - 21.75 kB - 03/09/2020 at 01:25
Download
chgbal-48v-charger-fb_interleave_2-100khz.asc
LTspice model of full bridge current fed converter.
plain - 3.31 kB - 01/06/2020 at 02:19
Download
chgbal-48v-charger-sepic_continuous-interleave_rearranged-100khz.asc
LTspice model of SEPIC interleave converter.
plain - 3.52 kB - 01/06/2020 at 02:18
Download
fb-vsense.zip
MPLab project of source for flyback measurement acquisition testing. Requires terminal emulator with TTL level RS232 interface.
Zip Archive - 427.17 kB - 12/04/2019 at 19:44
Download
chgbal-48v-flyback-opamp_drv.asc
LTspice simulation of constant on-time SR latch drive using op-amps.
plain - 4.70 kB - 12/04/2019 at 19:30
Download
chgbal-48v-la-flyback.asc
LTspice simulation of flyback measurement scheme.
plain - 3.88 kB - 12/04/2019 at 19:29
Download
chgbal-48v-la-flyback-pic.xlsx
Worksheet with PIC measurement data, coefficient, and accuracy calculations.
sheet - 10.23 kB - 12/04/2019 at 19:27
Download
