A Switch for the Core Panel
A project log for WDC-1 a "Working Digital Computer"
Make a computer based on the book "How to Build a Working Digital Computer" by Edward Alcosser, James P. Phillips, and Allen M. Wolk
michael-gardiMichael Gardi 12/19/2019 at 19:560 Comments
Most sizeable projects involve a number of side trips, and this one is no exception. From the Core Memory section of the book: "To read [core] memory, use the clip lead to simultaneously connect all four exposed wires for the address desired. See Fig. F-9."
In adherence to my no paperclip policy for this project I had to come up with an alternate method of selecting one of the five core memory "words". Looking closely at the CT-650 image below it looks like they used a rotary selector switch.
Cool, I could use a variant of my Mostly 3D Printed Rotary Switch, but when I started laying out the Panel it felt more like a slider switch would be a better fit. So I took a little side trip and designed one (based on my rotary switch).
The STL files and and construction details can be found in my Instructable: Mostly 3D Printed Slider Switch.
Here is a sneak peek at the Core Panel with the switch installed and a "fancy" knob. The Panel still needs to be wired.
