AirWolf
Open Source Air Quality Detector
Public Chat
It can detect carbon dioxide(CO2) , formaldehyde, VOCs/Volatile Organic Compounds or TVOC/Total Volatile Organic Compound, PM2.5/PM10/PM0.3, Temperature, humidity in the air.
AirWolf Demo Video
Adobe Portable Document Format - 486.92 kB - 12/09/2019 at 05:53
Preview
Download
16-AirWolf_V1.6-190927-JLC.PcbDoc.zip
AirWolf PCB Source File, designed by software Altium Designer
x-zip-compressed - 18.76 MB - 12/09/2019 at 05:46
Download
16-AirWolf_V1.6-1.pdf
AirWolf Schematic
Adobe Portable Document Format - 656.44 kB - 12/09/2019 at 05:44
Preview
Download
  • 1 × CO2 Sensor Sweden SenseAir LTD, S8 0053 CO2 Sensor
  • 1 × Formaldehyde sensor England DART SENSORS LTD, WZ-S Module
  • 1 × PM2.5/PM10 Laser Sensor China PlantPower LTD, PMS7003, PMS7003M
  • 1 × Temperature & Humidity sensor Switzerland SENSIRION LTD, SHT20 Sensor
  • 1 × VOCs sensor China Winsensor LTD, ZM01 IIC BUS VOCs MEMS Sensor
View all 9 components
  • Resources
    SaberOnGo12/09/2019 at 05:44 0 comments
    WIFI:
    1  my ESP8266 sdk in: https://github.com/SaberOnGo/ESP8266-AIRDOG
    ESP8266(ie: ai-thinker ESP-12F, esp8266 with 32Mbit SPI FLASH)
    http://wiki.ai-thinker.com/esp8266/docs
    2  ESP8266 SDK and resources on Espressif:
    https://www.espressif.com/en/support/download/sdks-demos?keys=&field_type_tid%5B%5D=14
    3  Android & iOS APP: https://github.com/SaberOnGo/AIRDOG-APP
  • AirWolf Functions
    SaberOnGo12/09/2019 at 05:43 0 comments
    Features/Functions:
     1  High-precision imported sensors: PM2.5, PM10, CO2, HCHO, VOC, temperature and humidity, etc.
     2  The system is configured with multiple sensors, including vibration, and PCB temperature detection.
     3  2.8-inch color TFT display with color screen display.
     4  Touch sensing, vibration sensing, intelligent adjustment of screen brightness at night.
     5  In addition to the 5V USB power supply, it is equipped with a large-capacity imported lithium battery to provide air movement for air quality detection.
     6  Built-in SD card, standard configuration 2G SD card, can store 5 years of sensor data, support up to 32GB SD card.
     7  can connect to the computer to view sensor data, virtual U disk supports FAT, FAT32, exFAT file system.
     8  Support online upgrade firmware, support remote firmware upgrade.
     9  equipped with WIFI module, support network control function
     10  Optional GPRS module, can be placed outdoors, remote detection in the deep forest.
     11  Configure the mobile app, including IOS and Android versions.
     12  Supports up to 800 mA charging function to quickly fill the battery.
     13  Reserved external interface to connect sensors such as oxygen, carbon monoxide, etc.
     14  Scrubed acrylic shell, so addictive ^-^.
     15  black gold plated PCB, noble and generous, lead-free solder, components are RoHS compliant.
View all 2 project logs
  • 1
    complile environment
    Compile Environment: Keil MDK-ARM 5.21a
    bootloader address: 0x8000000 ~ 0x8007FFF(see directory: ./bin/Booloader bin file/)
    application address: 0x8008000 ~ 0x803FFFF
    AirWolf Disk Config File(see directory: ./doc/disk config file/ )
    ./font/22.bin
    ./sensor
    ./update
    ./config.txt
    ./default
    ./system
View all instructions
greenhawk89 wrote 07/10/2020 at 06:23 point
Would this be a good set of sensors to put near an oil refinery? What if you made a map of like six of them across the city?
SaberOnGo wrote 12/10/2019 at 02:58 point
not that AirWolf :)
Tom Nardi wrote 12/12/2019 at 03:22 point
Glad I'm not the only one that heard this in their head as they clicked on the project.
Starhawk wrote 12/12/2019 at 03:26 point
LOOOOOL
I'd say "great minds think alike" but that only explains /your/ side of the equation ;)
