Small design change
A project log for High performance dorm room CNC
A (sort of) low cost CNC with broad capabilities and low storage volume
Oscar S.Oscar S. 12/12/2019 at 17:380 Comments
So i decided to change the Y-axis motor configuration. The design used to use one single NEMA17 Motor with a 600mm closed GT2 belt to drive the two leadscrews synchronously. However to simplify the tramming and tweaking of the physical unit, I decided to change it to two motors each driving it's own leadscrew.
Also, both Y-Gantry side plates are done, i'll post the result later on.
