Putting the frame together
A project log for Reaction Wheel Self Balancing Bike
This project is to track and document my A-Level DT project of a self balancing bike.
NickNick 01/17/2020 at 16:300 Comments
After all the pipes were bent I started putting the frame together using 5mm screws. Later I will add Epoxy to the joint so it doesn't slip.
