Pipe bending and drilling
A project log for Reaction Wheel Self Balancing Bike
This project is to track and document my A-Level DT project of a self balancing bike.
nickNick 01/17/2020 at 16:180 Comments
I then began to bend the pipe ends and drill holes into them to fit each other. I number the ends to make sure I was fitting the right ends together and the holes were drilled for the correct pipes.
