ATXMEGA VT100 Terminal
I Build a VT100 terminal 80 X40 colour characters using just a ATXMEGA2563AU and a 74lvc157
I used a Chinese 8" VGA monitor and a ATXMEGA to create this Vt100 terminal
I used TinyCad to make the schematic and FREEPCB to create the PCB files
The PCB is 7.5 x 6 cm
The Atxmega is running at 50.35MHz. According the manual its able to run 48MHz for full speed USB. and at 50MHz it's not getting warm at all. i have set it running for 5 days without any problems. i did try the internal clock multiplier running 2MHz x 25 and that works (kind of) its just not stable enough for a good picture
Xmega VT100.zip
Software
x-zip-compressed - 150.77 kB - 12/12/2019 at 14:42
Download
Terminal.bom
Bill of materials
bom - 1.26 kB - 12/12/2019 at 14:42
Download
Terminal.fpc
PCB file, FREEPCB
fpc - 118.00 kB - 12/12/2019 at 14:41
Download
Terminal.dsn
Schematic Diagram TinyCad file
dsn - 148.66 kB - 12/12/2019 at 14:40
Download
Terminal.dsn.pdf
Schematic diagram PDF
application/pdf - 35.77 kB - 12/12/2019 at 14:39
Preview
Download
