Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
RGBW IR Controller
Commercial grade analog RGBW LED stripe controller
EduardoEduardo
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
212
1
1
1
Team (1)
  • EduardoEduardo
Join this project's team
ongoing project
led RGBW arduino controller ir
This project was created on 12/14/2019 and last updated 9 months ago.
Description
This project is the evolution of the RGBW Analog/Digital Controller Shield, loose the digital controller and the USB command control, but its more user friendly and comes stand alone.
This controller can manage a RGBW analog LED strip with smooth transitions from an IR controller, and got many functions:
· Smooth color transition
· Power off memory
· 8 Memory colors
· Cycle mode
· IR Receiver
· Buttons (On-Off & Modes)
· Color toggle
· Color dimmer
· Settable transition time
· Settable cycle transition time
· Settable cycle stay time
· Settable cycle dimmer
Project Logs
Collapse
  • PCB
    Eduardo • 09/06/2021 at 00:18 • 0 comments
  • Documentation finished
    Eduardo • 12/23/2019 at 20:23 • 0 comments
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Ar wrote 12/14/2019 at 18:09 • point
Can't wait to see what you post =)
I needed a Xbee controller that is not just a bare PCB
Project Owner Contributor
Controller For My robotics projects
ap-techap-tech
Over engineered bluetooth ws2812 controller.
Weistek Neotroller
Jeremy g.Jeremy g.
DRV 10983 bldc controller
Blue-ESC : DRV 10983 bldc controller
YJ KimYJ Kim
An open source controller development workflow using OpenModellica for physics simulation and Icarus verilog for controller simulation.
Coupled Physics and FPGA Simulation
Adam LangeAdam Lange
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "RGBW IR Controller", please tell us the reason.
Send message
Remove Member
