PCB Revisions 1 Designed
A project log for 8-bit Counter
Ever want a display that slowly counts up in binary to 8-bits? Well this project does just that!
sirmylesaverysirmylesavery 12/16/2019 at 15:200 Comments
Back in October 2019, I finally got around to designing a PCB for the 8-bit counter. It uses the same components as the proto-boarded version, but in a small/more organized package. The design ended up being pretty simple. I used DIP packages, 5mm LEDs, and 1/2W resistors so that everything can be soldered easily by hand. No SMD components were used.
Below are some photos of the PCB design.
