climate_platform.yaml
climate platform I added to the configuration.yaml of HA
yaml -
1.21 kB -
05/25/2021 at 13:37
Download
A-C_Hitachi_converter.js
external converter for Zigbee2MQTT
javascript -
1.05 kB -
05/25/2021 at 13:37
Download
my_puny_program.ino
small program that serves as an intermediary between the air conditioner and the Zigbee modul
ino -
8.29 kB -
05/25/2021 at 13:37
Download
CC2530ZNP-with-SBL (Z-Stack 3.0.2).hex
Z-Stack 3.0.2 ZNP with booloader firmware for CC2530<br>(power sleep disabled, alternative pinout option activated)
hex -
680.76 kB -
08/02/2020 at 06:53
Download
CC2530ZNP-with-SBL (Z-Stack 3.0.2).bin
Same Z-Stack 3.0.2 ZNP with bootloader firmware for CC2530 but in bin format (to be used when flashing using a LOLIN Wemos D1 mini and CC loader library)
octet-stream -
256.00 kB -
08/02/2020 at 06:53
Download
Controller _ ON _ cool _ 27 _ high.sr
Data exchanged when turning on the air conditioner with the RAC adapter and central satation connected
sr -
1.85 kB -
06/14/2020 at 03:23
Download
Analysis result (2020_06_14).xlsx
Compilation of commands that can be send via RS-232 to the air conditioner
sheet -
14.82 kB -
06/14/2020 at 03:11
Download
No controller_OFF.sr
Data exchanged between the air conditioner and RAC adapter when no central station is connected and the air conditioner is OFF.
sr -
2.19 kB -
06/13/2020 at 01:43
Download
Analysis (2020_06_06).xlsx
Quick analysis of the data exchanged between the air conditioner and RAC adapter when no control station is connected.
sheet -
30.83 kB -
06/13/2020 at 01:36
Download
Measurement (2020_01_11).xlsx
Data returned by the air conditioner when pin 6 is tied to GND and after sending a "0"
sheet -
63.79 kB -
01/11/2020 at 06:21
Download
