And that's how it's done
A project log for Let me control you: Hitachi air conditioner
An attempt to wirelessly control an old Hitachi air conditioner
florianFlorian 05/25/2021 at 12:513 Comments
I did it... I achieved my goal... I can now contol my air conditioner from Home Assistant!
I'm so happy and proud of myself!
All went so fast in just a week I still can't believe it. Here is a brief summary of what I did and how:
   1. Using this GUI tool, I created a firmware with the following settings:
   2. Before closing the GUI tool, I used "Save custom converter for Z2M" to create the corresponding external converter for Zigbee2MQTT (see file A-C_Hitachi_converter.js).
   3. I flashed my Zigbee module, powered it up and then moved to Zigbee2MQTT dashboard in HA in order to add it. It appeared as an unsupported device with the name "RAS-LJ22Y_ADPT" so I followed the indication on this page and added it without any problem.
   4. Then I moved the external converter I previously created to /config/zigbee2mqtt/.
   5. Back to Zigbee2MQTT dashboard, I went to Settings > External converters, entered the name of the converter, clicked "Submit" and restarted Zigbee2MQTT. The result is as follow.
   6. I added a climate platform to my configuration.yaml following this documentation (see file climate_platform.yaml for more details.) and restarted HA.
   7. In the meantime, I wrote a simple program that retrieves the air conditioner status every 2 seconds, compares it to a previous known status and if different, sends it to HA in a JSON format. Also, this program send setting commands to the air conditioner according to what have been received from HA (see file my_puny_program.ino for details).
   8. Finally I added a "Thermostat card" in Lovelace and set the "Entity" to the climate entity I created.
I played a lot with this "Thermostat card", also played a lot with the infrared remote control and so far everything works perfectly, everything is in perfect sync. Only problem is how the material solution looks like for the moment...
Borlathe wrote 07/14/2022 at 04:03 point
So what is the point of the Seeduino/Arduino? Does the custom firmware still require an external microprocessor in order to control the CC2530? The flow chart looks like it is just taking in the asynchronous data and making it synchronous for the A/C unit.
Omemanti wrote 05/07/2022 at 07:59 point
You, good sir, just made my day.
Ken Yap wrote 05/27/2021 at 05:00 point
Well done! 👍 Perseverance pays. Give yourself a pat on the back.
