Based on the inspirations from hackaday and youtube I started my own bike powermeter
Not a member? You should Sign Up.
Already have an account? Log In.
View all 6 components
First test with the hardware has been very promising.
I was able to download the NordicSemi bikepowermeter TX example into my hardware.
After starting the firmware my powermeter connectec via ANT+ to my Garmin Forerunner 735xt and the simulated power and cadence was shown.
But now I do have problems with the software, is there someone who can help me ?
View project log
This is the module,
http://www.ebyte.com/en/product-view-news.aspx?id=445
what do you use for writing the code ? and drawing PCB ? thanks
I'm interested, can it be used with crank set ? what do you use for strain gauge sensor ?do you mind sharing the schematic ?thanks
Akshay Baweja
NsN
Laser Developer
Yes, delete it Cancel
You are about to report the project "Another Selfmade Bike Powermeter", please tell us the reason.
This is the module,
