Home Power Monitoring
With PZEM-016, monitoring of 3 phases in main electrical arrival of my house
Public Chat
My goal is to do an ESP circuit who is able to send to my MQTT server all 3 phases datas.The restriction :- 3 pahases non-intrusive electrical measurement- 1 UART to 3 UART MUX for ESP-8266- WiFi connection- MQTT connection compatible- 230V Powered- Node-red compatibleI choose to use :- 1x ESP-12 (ESP8266 based)- 3x PZEM-016 modified as details section- 1x MUX 74HC4052- Some passive components- Arduino IDE for ESP-12 with PZEM-004T_v30 library : <a target="_blank" rel="noopener noreferrer" href="https://github.com/mandulaj/PZEM-004T-v30-">https://github.com/mandulaj/PZEM-004T-v30-</a> Mosquitto MQTT server- Node-red on my Rpi home domotic server
PZEM-016 are normally RS485, I modified them to be UART 3.3V compatible
- Remove MAX485 IC
- Short-circuit pin 1 to 7 of MAX485
- Short-circuit pin 4 to 6 of MAX485
- R 3k3 0805 between pin 5 and 7 of MAX485 (do warn of short-circuits under resistor on pin 5-6-7)
- R 2k2 0805 between pin 3 of U1 and R13
JPEG Image - 3.41 MB - 01/18/2020 at 20:44
Preview
JPEG Image - 2.66 MB - 01/18/2020 at 20:44
Preview
JPEG Image - 3.22 MB - 01/18/2020 at 20:44
Preview
JPEG Image - 3.44 MB - 01/18/2020 at 20:44
Preview
JPEG Image - 2.68 MB - 01/18/2020 at 20:44
Preview
View all 13 files
  • 1 × PZEM-016 Voltage, Current, Power, Energy, Frequency, Phase sensor
  • 1 × Espressif ESP-12 ESP8266 wifi module
  • 1 × 74HC4052 Switches and Multiplexers / Analog Switches and Multiplexers
  • 1 × LM1117MPX-3.3 Power Management ICs / Linear Voltage Regulators and LDOs
  • 1 × Resistor 3.3k ohm 0805 Resistor 0805
View all 6 components
View project log
trator036 wrote 05/10/2023 at 13:00 point
Home power monitoring is an excellent way to track your energy consumption and identify areas for improvement. By installing a monitoring system, you can save money and reduce your carbon footprint. Additionally, if you're planning to renovate your home, consider hiring a reliable  kitchen renovations service to upgrade your cooking space and make it more energy-efficient.
bowllens wrote 12/19/2020 at 11:14 point
I like this monitoring system. Is this good idea to embed it on dynamic project? I want to setup it on my blog post of https://bestdehumidifier2021.com/best-dehumidifier-brands/
