To compile the Firmware in this two different boards is now easier after this update:
https://github.com/martinberlin/eink-calendar/commit/3a054bdb4976a6e7d708e9a14b2bc374a373d020
Update the line in platformio.ini to define in what board you want to compile:
; espressif8266 OR lolin_d32
default_envs = espressif8266
And set the SPI Pins in Config.h
We decided to use just GPIO integers and not anymore this D1->D8 Constants to keep it uniform across different environments:
// ESP8266 | ESP32 in comments
int8_t EINK_CS = 5; // GPIO 5
int8_t EINK_DC = 0; // 17
int8_t EINK_RST = 2; // 16
int8_t EINK_BUSY = 12; // 4
That's it. As a reference here is a Wemos D1 ESP8266 GPIOs
Lolin ESP32:
