CALE Waveshare 7.5" v2 E-ink back-case
A project log for CALE Low Energy Eink Calendar
Long-life battery powered photo frame that renders a Screen every morning and goes to sleep - CALE.es WebService to render Bitmaps
martin-fasaniMartin Fasani 01/25/2020 at 10:270 Comments
I added a very simple back-case replacement for the original Waveshare 7.5" white case with magnets. Designed also a small cover for the Eink HAT so it can be easily glued to the back of the Eink, making Epaper and HAT adaptor a single piece for easy mounting.
Please check the CALE 3D Model on Thingiverse.
CALE project has been sponsored by makers store digitspace.com
