Building Cale backend
A project log for CALE Low Energy Eink Calendar
Long-life battery powered photo frame that renders a Screen every morning and goes to sleep - CALE.es WebService to render Bitmaps
martin-fasaniMartin Fasani 02/10/2020 at 07:010 Comments
Still some days of hard work, but PHP framework Symfony is making it easy to design the forms and validation. The status so far:
Addding wizards that make easier the process of connecting APIs like Calendars, Todo apps and much more. Github issues is also going to be added, so you can list your open requests for your Repositories. The target can be your Eink:
But could be displayed publically or privately using the HTML version. There will only two options at launch:
- Open to the world
- Secured with a Bearer auth token. In that case an SSL version should be compiled otherwise the whole security thing makes little sense when your key is flying over the air unencrypted.
Please note that we are also offering to print T5S board housings for free if you register in CALE.es
CALE project has been sponsored by makers store digitspace.com
