Adding FocalTech touch interface support (FT6X36)
A project log for CALE Low Energy Eink Calendar
Long-life battery powered photo frame that renders a Screen every morning and goes to sleep - CALE.es WebService to render Bitmaps
martin-fasaniMartin Fasani 10/08/2020 at 14:340 Comments
Proud to announce that in last iteration of CalEPD we added touch support. A small code-snippet to inject Touch in the Gdew027w3T (2.7 inch from Goodisplay)
This is meant to be used as a component in the ESP-IDF Framework:
#include "FT6X36.h"
#include <gdew027w3T.h>
// INTGPIO is touch interrupt, goes low when it detects a touch, which coordinates are read by I2C
FT6X36 ts(CONFIG_TOUCH_INT);
EpdSpi io;
Gdew027w3T display(io, ts);
Priced at about 15 u$ this epaper is very cool to build small UX interfaces using epaper and ESP32.
