Overview
This guide provides instructions, code and components on how to build a internet enabled home automation system that allows scheduled control of multiple sonoff wifi enabled switches as well as routed control messages over the internet using the FlashLex IoT internet gateway.
Architecture Elements
Steps for Tasmota Installation
This isnt a Tasmota installation tutorial, there are tons of links above to get going on that. This is a cookbook for enableing your home automation hub to be a FlashLex device, so we will limit the instructions to that.
Important Links
Using esptool to flash Tasmota
Remember to hold the button down on the sonoff to put it in firmware update mode.
python3 -m venv ./venv
source venv/bin/activate
python
pip install esptool
pip install --upgrade pip
esptool.py -h
ls -l /dev/tty.usb*
esptool.py -p /dev/tty.usbserial-A50285BI write_flash -fs 1MB -fm dout 0x0 sonoff_6_6_0.bin
Installing the FlashLex Service
All the FlashLex projects rely on the FashLex SDK, which collects messages from the gateway using a locally running Python service. More information on installing the FlashLex service can be found in the FlashLex Docs.
Installing FlashLex SDK
The Sonoff Scheduler Hub Backend
Devices are managed and scheduled by code on the your FlashLex thing that sends commands to the individual sonoff switches over wifi. Essentially the sonoff switch software both automates scheduling of commands as well as provides a message manager for sending commands to your sonoff switches.
Sonoff Switch Commands
Message SyntaxSonoff SyntaxDescription
onPower%20onTurn the switch on.
offPower%20offTurn the switch off.
togglePower%20TOGGLEToggle the switch state.
Sonoff Scheduler Links
The Scheduler Config
For each switch that your scheduler will control provide an entry and the the schedule as well as the command you would like to send.
devices:
  - name: living-room
    ip: 192.168.8.59
    schedule:
      - time: "17:00"
        command: Power%20on
      - time: "23:41"
        command: Power%20off
      - time: "06:30"
        command: Power%20on
      - time: "07:54"
  - name: bedroom-01-tv
    ip: 192.168.8.199
    schedule:
      - time: "19:30"
        command: Power%20on
      - time: "01:01"
  - name: bedroom-01-lamp
    ip: 192.168.8.66
    schedule:
      - time: "17:00"
        command: Power%20on
      - time: "23:41"
      - time: "06:30"
        command: Power%20on
      - time: "07:54"
Creating the sonoff-switch service
You will want to have your sonoff switch running as a service so that even if your Raspberry Pi restarts it will come back up. To enable your sonoff-switch hub to run as a service install the service file and enable the service with systemctl.
$(pwd)/venv/bin/python3 makeservice.py -d $(pwd) \
   -t sonoff.service.mustache > sonoff.service
Instructions for setting up your service can be found at https://www.raspberrypi-spy.co.uk/2015/10/how-to-autorun-a-python-script-on-boot-using-systemd/
sudo cp sonoff.service /lib/systemd/system/sonoff.service
sudo chmod 644 /lib/systemd/system/sonoff.service
sudo systemctl daemon-reload
sudo systemctl enable sonoff.service
Creating the Scheduler Job
This project uses the python scheduler for automation. This allows for the creation of simple jobs that can send commands to the sonoff switches over HTTP.
    for device in config['devices']:
        for schedule_item in device['schedule']:
            schedule.every().day.at(schedule_item['time']).do(sonoff_job,
                ip_addr=device['ip'], sonoff_command=schedule_item['command'])
https://github.com/claytantor/sonoff-switch/blob/master/app.py#L66
and the job:
def sonoff_job(ip_addr, sonoff_command):
    print("setting {0} to {1}".format(ip_addr, sonoff_command))
    r = requests.get('http://{0}/cm?cmnd={1}'.format(ip_addr, sonoff_command))
https://github.com/claytantor/sonoff-switch/blob/master/app.py#L40
You can learn alot more about how to ticker with the Tasmota/Sonoff on the internet: https://lmgtfy.com/?q=sonoff+tasmota
Creating the FlashLex Listener Job
Now that you have a home automation framework in place, all you need to do is add a job that listens to your thing's MQTT queue and can route control commands to the switches.
def flashlex_job(config):
    lookup = {
        "on": "Power%20on",
        "off": "Power%20off",
        "toggle": "Power%20TOGGLE"
    sdk = FlashlexSDK(config)
    records = sdk.getSubscribedMessages()
    # process new messages
    for record in records:
        #print("record", record)
        #print("payload message", record['message']['payload']['message'])
        payload_message = record['message']['payload']['message']
        ## find the ip address
        result = list(filter(lambda x: (x['name'] == payload_message['device']), config['devices']))
        for device in result:
            ## find the command
            r = requests.get('http://{0}/cm?cmnd={1}'.format(device['ip'], lookup[payload_message['value']]))
        sdk.removeMessageFromStore(record)
https://github.com/claytantor/sonoff-switch/blob/master/app.py#L11
now you can add the scheduled job listener to your automation:
#schedule flashlex to accept commands
schedule.every(10).seconds.do(flashlex_job, config=config)
Sending Messages with FlashLex
You can use FlashLex to send control messages to your hub devices by name. Just send a message to your FlashLex Enabled device with the message schema.
curl -X POST \
  https://api.flashlex.com/prd/v1/things/5da91b24-28f2-4b55-829e-26528ba7a2eb/publish \
  -H 'Accept: */*' \
  -H 'Accept-Encoding: gzip, deflate' \
  -H 'Authorization: Bearer eyJraWQiOiJvQndJY0pCXONlNGM3ZQQkg5eWl1VTMzbXdKdz0iLCJhbGciOiJSUzI1NiJ9.Bgrx2LCv7fR-44-yb8EbfPZ1vutyPq8WCo8zDrlRjrBi3FNv0G1hIfy5-jJ1TVINdvLwFMpUQ_35LaN6UqU3sP00gYljgm1CydirhoLhvLFhcvomqqX_foCuKy1sGYM8gQFtEZIL7IJVkDiyHgND-DeFl6FDbfiDPBqhmHJE8i5XF-IMuL5jCOR7A610ZxUprg4_mR3TvUlhMTD4lp-prl2R7CNIeiaGfqgNNrey5wchDMpezc9oqmeoDneRtCqHUNBqm_hYSenyt_T_8wNmAV-sXPQ' \
  -H 'Content-Type: application/json' \
  -d '{"device": "bedroom-01-tv", "action": "switch", "value": "toggle"}'
 For more information on setting up the FlashLex SDK on your IoT device check out the SDK documentation at: http://docs.flashlex.com.s3-website-us-east-1.amazonaws.com/flashlex-docs/v1.5/sdk/index.html
