555 Roulette Wheel
LED roulette wheel using a 555 and 4017 decade counter.
I found this circuit on 555-timer-circuits and I had to make it!
I was looking for things to do with my stash of 555s when I found this fun little roulette wheel. I think it would make a neat interactive badge.
Then I found this video that explains it amazingly well:
  • 1 × 5-12VDC
  • 1 × 555 timer
  • 2 × 3.3MΩ resistors
  • 1 × 10kΩ resistor
  • 1 × 330Ω resistor
View all 11 components
  • O Fortuna!
    kristina panos12/29/2019 at 13:42 0 comments
    Got them working in circle format. Now I that I've verified the spin order, I can redesign that PCB. 😬
  • Fritzing around with vias
    kristina panos12/28/2019 at 13:55 0 comments
    Yesterday I went from
    • drawing my PCB plan out on the whiteboard, to
    • thinking it would be nice if I knew what I was doing enough to put some components on the back, like the coin cell holder at least, to
    • figuring out how to do it in Fritzing. Crazy! I've made my via bed and now I must lie in it.
  • It moves!
    kristina panos12/28/2019 at 00:57 0 comments
    Isn't that Jell-o cube LED awesome?
    I have no idea why it takes so long to slow down and stop. It wasn't doing that earlier. The suspense may kill you.
  • Breadboarding and resistor substitution
    kristina panos12/26/2019 at 23:37 0 comments
    I've breadboarded this up and it sort of works. I think the problem may be the extremely short leads on my 1uF cap, or else the fact that I don't have any 3.3MΩ resistors and substituted with three 1MΩ resistors in series. I do have six 100kΩ to make up the .3 on each, but I worried I wouldn't have the room. Time to rewire!
View all 4 project logs
wadonoj626 wrote 02/03/2020 at 17:56 point
Do you want to be rich and successful, but for this you are missing one step? I can definitely tell you the secret of success, but it’s better if you read it here https://casinolife.co.za/review/rich-casino it will just help you better understand which casinos are the largest and which casinos can be really baggy.
Mike Szczys wrote 01/06/2020 at 22:08 point
That's some sweet spinning action. The slow down is quite satisfying!
