Hackaday.io Hackaday.io
Sign up Log in
HMIFeatherWing
HMI FeatherWing with EA DOGM132-5 2.1" display and joystick compatible to Adafruit Feather
bernhardbernhard
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
183
0
2
1
Team (1)
  • bernhardbernhard
Join this project's team
  • HMIFeatherWing
completed project
hardware
adafruit feather arduino hmi display
This project is submitted for
  • Take Flight with Feather
This project was created on 12/27/2019 and last updated 7 years ago.
Description
The HMIFeatherWing gives you the possibility to easily add a HMI with a display and a joystick to your project. Just plug it on top of your Feather board and you can implement any HMI or menu structure you want.<br><br>The Feather Wing has a EA DOGM132-5 2.1&quot; display (<a target="_blank" rel="noopener noreferrer" href="https://www.lcd-module.com/fileadmin/eng/pdf/grafik/dogm132-5e.pdf">https://www.lcd-module.com/fileadmin/eng/pdf/grafik/dogm132-5e.pdf</a>) with a ST7565 controller and 132 x 32 pixel. The feather wing allows to control the backlight with PWM so you can dimm it and turn it off and on. There exists versions of this display with black or blue color and even a transflective one which even works with or without backlight and is readable in full sun light. You can use any Arduino library for ST7565 controllers or my DogGraphicDisplay library: <a target="_blank" rel="noopener noreferrer" href="https://github.com/generationmake/DogGraphicDisplay">https://github.com/generati
Files
HMIFeatherWing_schematic.pdf
Schematic
Adobe Portable Document Format - 118.53 kB - 12/27/2019 at 09:23
Preview
Project Logs
Collapse
  • HighPowerMotorFeatherWing
    bernhard • 12/30/2019 at 01:30 • 0 comments
    I used the HMIFeatherWing with my new HighPowerMotorFeatherWing to display the values of the motor.
    https://hackaday.io/project/169204-highpowermotorfeatherwing
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Clone of T-rex game from Chrome browser rewritten for Arduino
Project Owner Contributor
T-Rex-duino
alexanderAlexander
3D printed HUD display. Used in car to display maps, navigation, speed, time etc.
HUD display for cars
thiagesh-dthiagesh D
Modified Chroma74 shelf label to be my weather station display. It is 7.4" 3-Color E-Ink units that cost $12 on eBay.
7.4" E-Ink Shelf Label used as a Weather Station
yodalogicYodaLogic
This is Arduino 4-digit display shield
Arduino shield 4-digit 7-segment LED Display
marsMars
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "HMIFeatherWing", please tell us the reason.
Send message
Remove Member
