More Details on github. A youtube video shows a timelapsed animation.
I did it manually. Because it is a self made PCB without any vias, I had to solder it from top and bottom. And I had to do it in the right way, because you can not reach the inner Leds after all Leds are fixed.
How did you design the home-made PCBs? Layo1p for DOS? PCB trace tape? black pen?
👍 Wow, a lot of work to solder. Did you use any tricks to align the LEDs when you first made the clock face?
Impressive work!
