The jello_pudding Single Board Computer: Z80 10MHz 8/32 (Project Diogenes) is a Single board computer powered by a Z80 CPU running at 10MHz. It uses a Z80 PIO ship to communicate with a Arduino Nano what is used as an interface/Parallel to Serial converter in order to ease hardware and software design and development.
Why the long name?
I'm considering doing multiple projects with different CPU's, Clock speeds, and ROM/RAM configurations. These attributes will be noted as part of the name of the computer/project.
What's with the code name?
The code names are just notable Greek Philosophers picked in no particular order, makes it easier to refer to each computer in more causal conversation or with many reoccurring references.
