MCP4728 Breakout
A breakout board for Microchip's 4-channel i2c DAC with non-volatile storage
0 followers
The MCP4728 is an I2C quad channel 12-bit DAC with non-volatile storage, and a synchronous load pin for cases where channels need to be changed concurrently. This part is useful for applications where an analog trim value needs to be stored and loaded without firmware intervention.
  • 1 × MCP4728 Data Converters / Digital to Analog Converters (DACs)
