An animation clarification
A project log for Double-Oh Battery
A Wi-Fi-enabled power supply in AA-battery form factor. Originally designed for sex toys but has the potential for so much more!
Space BuckSpace Buck 01/05/2020 at 18:300 Comments
The question I've gotten the most is "Where does the LiPo go?" I hope this crude animation clears up how the parts fit together. Once the end-caps are in place, the entire assembly is 49.2 mm long and 14 mm in diameter. So tiny!!
