This project uses standard 5mm through hole LEDs and an DIP Attiny85.All SMD components are 0805, which can be soldered even by novices with a little practice.All pads are of the "handsoldering"-type, a bit bigger to account for the novice-factor :) The circuit and program is taken from http://www.technoblogy.com/show?2H0K
