A project log for LabDroid
Happy Prototyping powered by Android
HerrHerklotzHerrHerklotz 01/24/2021 at 09:450 Comments
Finally I could implement the last missing part of my concept for LabDroid: Variables!
Now it's possible to store information and reuse them on another run of the same project.
For example: If you would make a RC controlled car which is equipped with an Android phone running LabDroid, you could store/accumulate usage data like driven distance or used energie.
How to use
1. Step: Add the variables you need. You can choose between number or string as a dataytype. The String datatype can also be used to store JSON serialized objects.
2. Step: Connect them to your script.
3. Step: Use them in your script. :)
4. Step: And here is the result!
Note: The variables will be saved if the project is finished. During runtime they stay in the memory to provide the best possible performance.
Beside of another feature I will add this year, I want to focus more on making the application stable, improve UX and add more components.
WIsh you a nice sunday!
