Design: LC2D
A project log for Lowest Complexity Laser Cutter
simple, low-cost DIY diode laser machine
jason-choJason Cho 03/21/2020 at 16:200 Comments
LC2D, or Lowest Complexity 2D Gantry, refers to the overall frame & drivetrain of LCLC, not including the laser part. You can use the gantry with other things like a whiteboard marker or a laser pointer (for long-exposure shots) or whatever else you want.
Design Intentions
https://cdn.hackaday.io/images/166001584811572829.pngSo far, it's a success.
Renders
https://cdn.hackaday.io/images/6629641584810103875.jpgExplore the design in here!
(You can download the model as well.)
