Hackaday.io Hackaday.io
Sign up Log in
MIMXRT10xx Feathers (RT1011 and RT1062)
Two Feathers featuring the NXP i.MX RT10xx series Cortex-M7 MCUs.
arturo182arturo182
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
1 comments
22 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
1.6k
1
22
21
Team (1)
  • arturo182arturo182
Join this project's team
hardware
ongoing project
NXP mimxrt CORTEX-M7 Feather circuitpython unlimited_powaaaaaah
This project was created on 01/08/2020 and last updated 5 years ago.
Project Logs
Collapse
  • Your help is needed
    arturo182 • 11/07/2020 at 20:07 • 3 comments
    Hi!
    The i.MX RT 1011 + ESP32 Feather is ready for production, but I need to gauge interest to know how many to produce. Please help me by subscribing to the wait list on Tindie:
    https://www.tindie.com/products/arturo182/nxp-mimxrt1011-feather-with-esp32/
    This is not a binding transaction so even if you're on the edge, just sub anyway :)
    This also makes sure that you will get an email when the boards are ready!
    Thanks!
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Xasin wrote 11/10/2020 at 11:41 • point
This makes me quite curious - what problem were you trying to solve by combining the already quite beefy ESP32 with an even beefier Cortex CPU?
It looks like a really well designed board, in any case, but if I wanted WiFi I'd go just with an ESP32, and if I need processing power I'd use a MCU like the RT 1011 with a barebones WiFi interface like an ESP8266 in AT-Command mode.
LoRaWAN livestock tracker deluxe
Project Owner Contributor
BaaPS (Baa Positioning System)
jacobJacob
A streamlined HUD - also a challenge for myself
HUD That Shows You Notifications
nagupnagup
Simple and cheap configurable ESP32 based controller for wired sensors and relays
Chipperb
jason-kJason K
An open source, PoE+, ESP32 devboard with a mikroBUS socket.
Espoir
marc-antoine-lalondeMarc-Antoine Lalonde
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MIMXRT10xx Feathers (RT1011 and RT1062)", please tell us the reason.
Send message
Remove Member
