Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Events Hackerspaces Profiles Hackaday.com Tindie Marketplace Remoticon
Sign up Log in
MIMXRT10xx Feathers (RT1011 and RT1062)
Two Feathers featuring the NXP i.MX RT10xx series Cortex-M7 MCUs.
arturo182arturo182
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
21 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
842
1
21
19
Team (1)
  • arturo182arturo182
Join this project's team
hardware
ongoing project
NXP mimxrt CORTEX-M7 Feather circuitpython unlimited_powaaaaaah
This project was created on 01/08/2020 and last updated 3 months ago.
Project Logs
Collapse logs
  • Your help is needed
    arturo182 • 11/07/2020 at 20:07 • 3 comments
    Hi!
    The i.MX RT 1011 + ESP32 Feather is ready for production, but I need to gauge interest to know how many to produce. Please help me by subscribing to the wait list on Tindie:
    https://www.tindie.com/products/arturo182/nxp-mimxrt1011-feather-with-esp32/
    This is not a binding transaction so even if you're on the edge, just sub anyway :)
    This also makes sure that you will get an email when the boards are ready!
    Thanks!
View project log
Log In/Sign up to comment
Sign up with Github
OR
Xasin wrote 11/10/2020 at 11:41 • point
This makes me quite curious - what problem were you trying to solve by combining the already quite beefy ESP32 with an even beefier Cortex CPU?
It looks like a really well designed board, in any case, but if I wanted WiFi I'd go just with an ESP32, and if I need processing power I'd use a MCU like the RT 1011 with a barebones WiFi interface like an ESP8266 in AT-Command mode.
Building an FM Radio Station For Hackers Everywhere
Project Owner Contributor
107.9 FM -- End Of the Dial -- Hacker Radio
Saint MehSaint Meh
The 2015 Hackaday Prize
Equus is a simple and green way to get homeless off the streets and back into the work force using modified horse trailers as new homes.
Project Equus
nahoveynahovey
I made dozens of masks in 2020. This is my method.
how I make masks
kristina panoskristina panos
I need a mini mill and I am attempting to build one as cheap as possible.
DIY mini mill
RX HMPRX HMP
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "MIMXRT10xx Feathers (RT1011 and RT1062)", please tell us the reason.
Send message
Remove Member
