Here is a picture of the machine frame, which is made of 12x 500mm 3030 profiles.
Will build the X, Y, Z axis and if the dimensions are to small I will use greater ones. The electronics and filament spool could be later mounted on the sidewalls.
The next thing will be upgrading the power supply with more resistors.
