Testing with Shielding Gas
A project log for Wire 3D Printer
A 3D printer for printing with welding wire
dominik-meffertDominik Meffert 03/21/2020 at 22:252 Comments
I tried out spraying CO2 and Argon Gas on the melted metal while printing, but unfortunately I couldn't see any difference in print quality. Maybe I did something wrong or it has something to do with using resistance welding instead of arc welding. Will maybe test it again in the future...
Dominik Meffert wrote 03/23/2020 at 12:20 point
I couldn't notice any difference, but maybe I did it wrong. I just sprayed it per hand on the melted wire. Maybe the gas has to flow throug a shielding gas nozzle to shield the melted metal as intended, but that would need a redesign of the toolhead. I think I will repeat the test with a shielding gas nozzle when the wire feeder works reliable.
Krzysztof wrote 03/22/2020 at 17:26 point
Was metal finish better or did it still looked oxidised?
