Hackaday.io Hackaday.io
Sign up Log in
TS100 USB-C easy and cheap hack
Just a quick hack how to power TS100 soldering iron using power bank with Power Delivery
robert-mordzonRobert Mordzon
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.5k views
1 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
4.5k
1
7
13
Team (1)
  • robert-mordzonRobert Mordzon
Join this project's team
  • Video
  • USB-C Trigger
completed project
hardware
ts100 soldering iron USB-C Pd power delivery quick hack trigger power bank
Related lists
Gotta Remember
Projects I'm going to have to try.
Power Projects
Projects involving batteries as main point
This project was created on 01/12/2020 and last updated 7 years ago.
Description
TS100 is my favorite mobile soldering iron.<br>It is small, handy and powerful but 6S LiPo battery which I was using to power this is not handy at all.<br>So I made this simple and cheap hack to power TS100 using power bank.<br><br>You need:<br>USB-C PD Trigger: <a target="_blank" rel="noopener noreferrer" href="https://www.aliexpress.com/item/4000124529027.html">https://www.aliexpress.com/item/4000124529027.html</a><br>DC CONNECTOR: 5.5mm x 2.5mm<br>Cable: USB-C USB-C<br>Power Bank: BASEUS POWER-BANK 20000 mAh (15V 20W)<br><br>You can use a better power bank with 20V PD and get more power but I already have this cheap Baseus one with 15V PD and it works very well.<br>You can also use wall charger with PD.<br>USB-C PD Trigger is 2.5$ adapter that triggers higher available power mode form power bank.<br>Use regular USB-C cable to connect it together. (Thunderbolt 3 cable is also OK)
Details
Components
  • 1 × USB-C PD Trigger 20V https://www.aliexpress.com/item/4000124529027.html
  • 1 × DC CONNECTOR 5.5mm x 2.5mm
  • 1 × Power Bank with Pover Delivery
  • 1 × USB Cable USB-C <-> USB-C
  • 1 × 2 wire cable
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
rafununu wrote 01/15/2020 at 05:56 • point
How can they deliver 20A (or more !) in USB connectors ?
USB-C Power Adapter for Commodore 1541-II Floppy Disk Drives based on CH224K
Project Owner Contributor
C64 USB-C to 1541-II Power Adapter
stefan-wagnerStefan Wagner
Effectively powering an ESP8266 requires a proper power supply - here's a very cheap simple solution
A cheap simple ESP8266 power supply
stuart-gogginstuart goggin
A programmable power supply that's both USB-powered and reasonably capable
USB PD Bench Power Supply
clara-hobbsClara Hobbs
TLV740 Virya is an affordable,ultra portable,power supply that provides fixed outputs of 3.3V&#x2F;2.8V&#x2F;1.8V from a 5V input.
Mini Benchtop USB powered power supply
vijayasarathy-shastriVijayasarathy Shastri
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "TS100 USB-C easy and cheap hack", please tell us the reason.
Send message
Remove Member
