Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
68010 / 68451 MMU Homebrew
A homebrew computer built around the 68010 with the companion 68451 MMU
John SonnenscheinJohn Sonnenschein
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
2 comments
8 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
Public Chat
771
2
8
6
Team (1)
  • John SonnenscheinJohn Sonnenschein
Join this project's team
  • KiCAD files
hardware
ongoing project
68k m68k MMU RETRO 68451 m68451 m68010
This project was created on 01/15/2020 and last updated 2 年前.
Description
the 68451 MMU was made as a companion for the 68010 CPU, Motorola's first CPU to support virtual memory. There are very few examples of machines built with this combination, and neither Linux nor NetBSD support it (yet). Most 68010 machines were either built with no MMU at all (being a minor upgrade from the 68000), custom MMU's (for instance the Sun-2), or the generation was skipped entirely for later M68k CPU's that included on-chip MMU.
Files
68451_Memory_Management_Unit.pdf
Manual for the 68451
Adobe Portable Document Format - 2.40 MB - 11/05/2020 at 23:58
Preview
Download
Project Logs
Collapse
  • Early research
    John Sonnenschein • 03/01/2020 at 21:40 • 0 comments
    I've found exactly one example of schematics of a machine that used the 451 at https://archive.org/details/bitsavers_compuproA1nualNov83_1763479/page/n7/mode/2up
    Unisoft was a company in the 80's that ran around porting UNIX to various things, and they have a version of UTSv7 on bitsavers: http://bitsavers.org/bits/Unisoft/V.1.5+/sys/
    and finally, the retrobrew community has peripheral boards and compute boards that use the 68000. Presumably we can shoehorn the 68010 in to there (it was pin compatible) with the 451 in between https://www.retrobrewcomputers.org/doku.php?id=boards:ecb:mini-68k:start
View project log
Log In/Sign up to comment
Sign up with Github
OR
Watchm4ker wrote 04/12/2020 at 09:07 • point
I've poked at this idea myself, ever since I saw the MMU. From what I can tell, between the 68000's botched page fault handling, and the limited capabilities of the 68451, most system designers used their own MMUs. That S-100 card's a good find, though I had a thought of using VMEBus. After all, it was designed for backplane 68000 machines from the start.
RW wrote 03/01/2020 at 22:17 • point
Hi John, there's some documents in the hardware directory on Aminet that cover swapping their 68000s over to 68010s, so you may find them of use when using an 010 in an 000 design.
Porting the classic Doom engine to an FPGA-based system
Project Owner Contributor
FPGA Doom
Matt StockMatt Stock
I build TD4 CPU and expand it (add RAM, switchable memory banks and rugged I/O)
4-bit CPU (TD4 once again)
Fedor GruzdevFedor Gruzdev
Single board computer (128KB SRAM) build in 1991.
68000 minimal homebrew computer
StevenSteven
Modular 8-bit computer system based on the WDC 65C02 and a mix of modern hardware.
Herring 6502 Computer
Colin MaykishColin Maykish
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "68010 / 68451 MMU Homebrew", please tell us the reason.
Send message
Remove Member
