Opening Configuration
A project log for Gameduino 2: Server
40 Gameduino Boards, Large Screen Monitor, 3TB External Hard Drive, Wireless Gaming Keyboard
darksider7Darksider7 07/01/2014 at 00:570 Comments
I'll work it out on paper to obtain perspective on how this will look, then, wiring and programming this rather large "Pi Hack" should pose a unique challenge for this long-time gamer (since 1980...) to be exact.
UPDATE: 1
It's been a while since I've last updated this log, now, working on the server end of the project. The specs look great, but it's been a trial and error getting this server to have the constant signal that I need, keeps tampering off, after a period of time (for an example: one hour...) then it's fading. I need a source with a more dedicated signal or it could be in the construction, time to find that glitch.
UPDATE: 2
The server is going through some renovations, instead of shelving the system will be transferred into a server encasement. The boards will be stacked in two rows of ten, it's width and depth is expansive and has room for wiring and other various connections. The nodes will be secured down so the encasement can be moved without interrupting or breaking the internals. I'm going to customize a wireless controller to work with the server.
UPDATE: 3
I have discovered a wireless controller (sophiscated with primary functions...) and those extras that do come in handy. As far as hacks are concerned it's gonna need two monitors (1. for preview) and (2. for LIVE action) while gaming online or broadcasting gameplay. In the works, thinking, motion control using hand gestures and began construction on such a controller (of course the Nintendo WII has such a device as a standard right out of the box...). To be original add on a way to turn on the machine just by moving one finger toward the server.
UPDATE: 4
The device will have the capability to network with "Rasp-Pi," "Microsoft," and "MAC" servers on a number of various platforms. Though, not inexpensive, working around settling on.a ORACLE system, networked to my MAC PRO, and my Gameduino setup. I want to conduct an experiment on "connectivity" and just the number of servers it will accept
