I did a thing
Best use is as a terminal you setup in a remote location it's got a hefty battery on it. it doesn't pass through charge so while the battery
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I built a thing , it was fun got stuck gave some things I need to order and make for it. A better way to draw more power out of the battery. Touch screen is not working need to check that .
