I get the wired Ethernet working on GalliumOS
A project log for Restoring an Asus Chromebox CN60
Free computer if I can get it working
ken-yapKen Yap 01/18/2020 at 22:512 Comments
One oddity is that the wired Ethernet doesn't work under GalliumOS. ifconfig shows no wired interface, only the wireless one. ChromeOS had the wired Ethernet running so it's not a matter of no driver available. A search found a complaint by somebody who got various Linux distros running with a working wired interface, with the exception of Ubuntu. What is it about Ubuntu, which GalliumOS is derived from?
Most likely the driver is in a package not in the ISO, and this has to be installed separately. lspci shows that the Ethernet chip is a Realtek r8168. apt search r8168 turns up a package called r8168-dkms. DKMS is Dynamic Kernel Module Support. This means the driver contains a binary blob or something which makes it impossible for GPL purists to distribute as a binary package. Instead the driver source files are distributed in a package that recompiles the driver against the current kernel when installed or when the kernel is changed.
Installing the package still didn't get me a driver. There was no driver in the the current kernel modules, but there was something matching in an unrelated directory. There was a message towards the end about failure to recreate the initrd. I looked at the error message left in the install log and it turns out that I need to install libelf-dev. Then I ran dpkg-reconfigure r8168-dkms and this time it created a r8168.ko in the current kernel modules.
Still not out of the woods yet. For some reason the interface doesn't come up on boot, but doing ifconfig r8168 works. I'll have to look at this later.
Keith wrote 05/02/2020 at 05:45 point
Hi Ken, thanks for posting this. Any update? I have the same issue, on an Asus CN60. Just installed it for the first time, and I'm scratching my head.
Edit: All set now, this works, I just joined my wifi network for internet connectivity, then did a "GalliumOS Update" on the menu. Now the RealTek ethernet driver is installed. (Note, I had checked to enable the nonfree repositories during the original install). PS this is using GalliumOS 3.1.
Ken Yap wrote 10/14/2021 at 05:55 point
Sorry, I didn't see your comment until now. Good that you got it to work already. Usually with Linux the answer is you can but it may take a bit of experimentation. As you can see from the following log entries, I ditched GalliumOS in favour of openSUSE almost right away so I never went down that path.
