Y axis scale rough mounted
A project log for Reviving a Shoptask 1720 XMTC Gold 3-in-1
This thought project is notes on reviving my 1998 Shoptask 1720 XMTC Gold late-mill-drill
alastair-youngAlastair Young 03/17/2020 at 06:350 Comments
taps and drill arrived from drillsandcutters.com and transfer punches from harbor freight. The y scale ia almost fitted. I need to make end brackets that will do:
The cover is 16mm longer than the scale and comes with a vertical lip to allow you to screw it to a flat surface. I bent/hammered that lip flat as the top of the cover will be flush with the table. This also makes it wide enough to reach out over the head bracket.
