ARX MK0S
This is the servo variant of the ARX Hand Project which focuses on being an easy to develop robotic hand using common RC servos that can be easily sourced and controlled.
ARX MK0 Variants
Design Intentions
This design is more of a fun low cost design I made that may be used in STEM education for inspiring future engineers and makers. I may work further on the design for other possible purposes.
Design Aims
Design Overview
The design brings 5 degrees of actuation using servos along with 11 degrees of freedom in joints. It uses 5 micro/mini RC servos which can be controlled using an Arduino, a PWM driver or any servo driver. The use of servos brings the ability to have the fingers actuated to a set position through standard servo control. The servos can also be modified if there's a need for greater control and feedback of the fingers. Lifting and holding capabilities are dependent on the servos used, so ideally a high torque servos should be used if possible. Currently, the design will be compatible with the SG90, MG90S or any similar sized servos. Hand parts can be printed using any printer capable of printing PLA, and can be printed with or without supports. Additional materials required are some self tapping screws, 3mm nylon filament, 1mm diameter elastic cord and 0.5mm to 0.8mm diameter braided fishing line.
Hand Design
3D Printing
The ARX Hand Project can be printed using any standard FDM printer that can print PLA. Majority of prototypes I have printed are in PLA using a fairly modified RepRapPro Huxley 3D printer purchased in 2014. The design has been based around 0.2mm layer height with a 0.4mm nozzle, so using different parameters may affect part fit. Some additional small geometries have been added to the models to compensate for some effects caused by 3D printing.
No supports are needed when printing out all parts, however, if there's inadequate cooling of the undersides of joints, supports may be needed. Parts can be printed without brim for materials like PLA and PETG, but bed adhesion should be made as strong as possible for finger joints as they are prone to warping due to their length. The use of a removable flex bed is recommended to allow for easy part removal if print is adhered strongly to the bed.
Typical print specifications:
Print materials:
Disclaimer
Although I have some experience in designing things from being self taught, I do not have any degree or qualification as of writing. This design therefore should not be used as a medical device or to be used in any situations where it may cause injury or harm. I can not be liable to any injuries, harm, or issues resulting from the design and therefore should only be used at your own discretion.
License
This work is licensed under a Creative Commons Attribution-NonCommercial-ShareAlike 4.0 International License.
