This project has been made to replace my original instrument cluster, which was old, dirty and broken in few places.
First I created developement prototype with STM32 blue-pill board, breakout board with LCD and x27-168 stepper motor from aliexpress. Next I had to do some measurements on a motorcycle's electrical wiring. Then came creating firmware for a microcontroller. When my desk transformed into a a mess made from breadboards and cables, i decided to make a PCB to connect everything. First revision was a fail, so I made a 2nd. When hardware worked, then time came to finish up firmware. Right now device is working on my bench, haven't been tested on a motorcycle because winter is really not the best time for a ride.
Essential parts are:
- ILI9341 2,8in LCD with SPI interface
-X27-168 stepper motor for dial gauge
-M95320 SPI EEPROM to hold data like mileage and daily trip
-NTC100k thermistors to measure temperature
-custom made front wheel encoder to measure vehicle speed
Firmware source code, PCB design and schematic, and also 3D models of enclosure are available on my GitHub
https://github.com/wiciu15/motoHUDini
