At idle, the system consumes about 1.5 kW of electricity and maintains a stable temperature of about -20 °C inside the rack (about -17 °C in summer).
The refrigeration compressor is driven by a VFD, which, like everything else (including the fans), is controlled by a microcontroller.
The evaporator and condenser were taken from an old window air conditioner. The compressor was selected separately, based on the required performance and its operating temperature conditions.
The condenser is cooled by cold outside air, which is first filtered through car air filters.
The warm air is released into the surrounding room, from where it is efficiently drawn out by a passive exhaust ventilation system.
The purpose of this post is to highlight the problems behind the desire to keep a home lab / rack servers in proper conditions – mainly dust and heat.
The cooling system consumes about 750 W. Each server consumes about 250–400 W; each of the two servers contains 3 compute nodes with two 6-core processors each – 72 cores in total, so to speak.
All of this is in standby mode.
In most cases, I use one compute node as NFS / iSCSI network storage, and sometimes one more node as a hypervisor for work. I rarely use the remaining nodes – mainly for distributed builds of the kernel / world or ports. So they stay turned off most of the time, which further reduces power consumption.
With my electricity tariff of $0.037 per kWh during the day and $0.018 per kWh at night, this is not that much (~$320/year, if I calculated correctly).
Moreover, all of this equipment can be turned on and off remotely with one click if necessary.
The normal temperature should be around 17 °C. However, with such a small volume and such cooling capacity, I cannot maintain a stable temperature under varying loads, and I think fast cyclic temperature changes would be more damaging to the equipment. At -20 °C, temperature swings under varying loads do not exceed 1–2 °C per minute, while at higher temperatures the spread is ten degrees or more. The inertia of the system turned out to be too great to compensate for with my PID control, and I don't think I can succeed with this system configuration.
I had to modify the server's ear, which contained a thermistor connected to the fan control board. I replaced it with a digital potentiometer driven by a controller and a digital thermometer; otherwise, when the temperature drops below zero, an overflow occurs in the fan control board, which then thinks the temperature is above 200 °C and runs the fans at 100% :)
Two+ years of operation in these temperature conditions have not revealed any problems so far, such as degradation of capacitance or ESR of the capacitors. Judging by the voltage charts, the voltages have been pretty flat the whole time. Perhaps this is just luck, since all the capacitors are solid-state. The only exception is the power supplies, but they stay quite warm even at this ambient temperature.
But I think I need to look at the waveforms during continuous operation...
By the way, slightly off-topic: the biggest problem was the VFD, which caused constant glitches in RS485 communication (later replaced by Ethernet transceivers) and in all other subsystems. Whatever I did and whatever filtering I applied, floating problems persisted until the VFD was isolated with a separate isolation transformer, a shielded enclosure and an EMI filter (because the 10 kHz harmonic component somehow propagated backwards, even through the isolation transformer), plus optical isolation for the control signals. Shielded lines alone did not help. I'm not sure if this is good practice, but the compressor with its VFD ended up completely galvanically isolated from everything else, with no common ground. Only the shielding is connected to the common ground through a capacitor.
EE was part of my education, but unfortunately we did not study...
Andrew Shevchuk
clint blunier
Jeff Thomas
Tim Bishop
