wav2c.cLinux command line application to convert media/sound files into C source PCM data to be linked directly with embedded applicationsC Source File - 5.93 kB - 02/15/2020 at 06:01 |
dt_numbers_7.hSound samples to be linked with the dice tower applicationh - 217.72 kB - 02/15/2020 at 06:01 |
main.cProgram source code for the "Heathkit 1979 Digital Dice Tower. Developed with Atmel Studio 7 for the ATmega 328.C Source File - 16.15 kB - 02/15/2020 at 06:01 |
