I've build an digital clock made out of 144 7 segment displays controlled by an arduino nano. The segments are controlled by 18 MAX7219 ic's which can control up to 64 individual leds or 8 7 segment displays. The array has 144 displays made each up of 8 individual leds so the array has an total off 1152 leds you can control.
(Note: when building this clock make sure the Tiny RTC’s headers are upside down so the battery faces downwards.)
Did anybody make this clock work with an ESP8266 module via NTP server instead of an Arduino. If so I would greatly appreciate it if I could get the code from you. I would appreciate it even more if the time was 12 hr instead of 24 hr. I am still a beginner when it comes to coding.
