Hackaday.io Hackaday.io
Sign up Log in
PiBox
Just a conversion from an empty drill bit case to a Raspberry Pi laptop by laser cutting some inserts and plugging things together.
rich-maynardRich Maynard
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 6
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
371
3
4
7
Team (1)
  • rich-maynardRich Maynard
Join this project's team
ongoing project
This project was created on 01/24/2020 and last updated 5 years ago.
Description
A convenient way to cary around a Raspberry Pi, screen, keyboard, power supply, breadboard and a few components.
Components
  • 1 × Raspberry Pi
  • 1 × Official Pi 7" touchscreen https://www.raspberrypi.org/products/raspberry-pi-touch-display/
  • 1 × Drill bit case https://www.ebay.co.uk/itm/Titanium-Coated-HSS-Drill-Bit-Set-99-Pcs-Piece-and-Case-Wood-Metal-Kit-1-5-10mm/164038303500
  • 1 × KK Moon keyboard https://www.ebay.co.uk/itm/KKmoon-59-Keys-Ultra-Slim-Mini-Wireless-Bluetooth-3-0-Keyboard-w-TouchPad-Panel/223000373931?epid=26024513508
  • 1 × 18650 battery pack https://www.aliexpress.com/item/32968744615.html
View all 6 components
Project Logs
Collapse
  • Screen inversion
    Rich Maynard • 01/27/2020 at 15:57 • 0 comments
    Turns out that the Pi display has a better viewing angle from one direction than the other. The Pi Foundation flipped the display to account for this, assuming that the user would be looking down on the display from above.
    In my case I think the user will be looking from 'below', so turning the display over makes sense. Which means I don't have to lengthen the jumper wires, but I do need to make some modifications to the mounting hole positions and screen cutout.
    More info and software fix:
    https://support.thepihut.com/hc/en-us/articles/115002072865-Official-touchscreen-is-upside-down
  • Improvements
    Rich Maynard • 01/24/2020 at 14:36 • 0 comments
    There are a few changes that need making to the arrangement of parts:
    • Jumper wires need to be longer to provide power to the Pi from the screen
    • Jumper wires need to be longer so touchscreen can work over SPI
    • Battery needs to move to right so power supply cable actually fits in around screen (component box could then be a bit bigger)
    • Component box doesn't line up properly with its lid
    • Would be nice if it were a little easier to remove component box
    • Paint it, or maybe use some veneered MDF instead
  • First draft of the assembled PiBox
    Rich Maynard • 01/24/2020 at 14:20 • 0 comments
    Opening the case to find a removable Bluetooth keyboard
    Removing the keyboard gives access to the 7" touchscreen
    Removable lids cover the Pi, breadboard and a little compartment to store components
    USB hub to allow better access to Pi USB ports
    Cutout allows access to the button on the battery to display charge level (red LEDs)
    Component box is removable to allow access to Pi HDMI and power ports
  • Starting to work put where everything goes
    Rich Maynard • 01/24/2020 at 14:11 • 0 comments
    First view of the bits to include
  • Power source
    Rich Maynard • 01/24/2020 at 10:57 • 0 comments
    I chose this power source as it can provide 5v via the USB connector, but also has onboard solder pads to provide 5v, 9v and 12v which might be useful for projects
    I used a couple of 18650s reclaimed from an old laptop battery pack
  • Introduction
    Rich Maynard • 01/24/2020 at 10:49 • 0 comments
    I had an unused drill bit case and a Raspberry Pi, so put them together with some other components to make a laptop aimed at makers.
    I looked around for a supplier of the drill bit case without the drills, but can't find one. You can get the case and 99 drill for less than a tenner on eBay anyway.
View all 6 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Rich Maynard wrote 01/24/2020 at 18:04 • point
The lid isn't deep enough, you're right. At least with the driver board attached to the back of th screen, anyway, and it would be a lot of trouble to mount the driver separately - the connecting ribbon cable is very short!
Dan Maloney wrote 01/24/2020 at 17:06 • point
Seems like it would have been natural to mount the screen in the lid so it could be used like a laptop. Any reason why you chose to put the screen in the base? Maybe the lid isn't deep enough?
And the lid flops all the way open, so would need some kind of bracing to hold it open at a suitable angle
An easy to build rugged-ish, portable-ish raspberry pi with a 10.1 ins screen and a 40% mechanical keyboard.
Project Owner Contributor
Portable Pi
jefmerjefmer
Battery powered Linux-terminal handheld with front and rear inputs, 4.3" DSI LCD, a Pi 3A+, and GPIO breakout. WIP.
Thumb Term
dan-a8ksh4Dan (a8ksh4)
raspberry pi inside a pelican case with 3d printed parts
Portable Raspberry Pi with LCD + keypad
shane-bourgeoisshane bourgeois
I will be building a Carputer utilizing a Raspberry Pi3
Raspberry Pi Carputer
randy-walkerRandy Walker
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "PiBox", please tell us the reason.
Send message
Remove Member
