First draft of the assembled PiBox
A project log for PiBox
Just a conversion from an empty drill bit case to a Raspberry Pi laptop by laser cutting some inserts and plugging things together.
Rich MaynardRich Maynard 01/24/2020 at 14:200 Comments
Opening the case to find a removable Bluetooth keyboard
Removing the keyboard gives access to the 7" touchscreen
Removable lids cover the Pi, breadboard and a little compartment to store components
USB hub to allow better access to Pi USB ports
Cutout allows access to the button on the battery to display charge level (red LEDs)
Component box is removable to allow access to Pi HDMI and power ports
